跳转到主内容
The Huawei P8 Lite (Model: ALE-L21) announced April 2015, shows beauty in simplicity. Its professional cameras enable you to take natural and sharp pictures even in the darkest environment. The beauty mode highlights the best features of the owner in every selfie.
112 个问题 查看全部
Dropped my phone in sea. help! CAN FIX IT AFTER 15 hours?
Hey guys yesterday my phone dropped in a gulf at midnight...if I swim at the morning and I can take it. It is 1.40 m from the ground
Update (07/12/2018)
I disassembled all in the phone expect the lcd and ear vibrator. . I have to roll it off completely or I can drop it with the pieces in the liquid you told me about.
And correct I am from Greece..also The battery is for rubbish now
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
If you're in Greece as your name hints to, it's just a pleasant swim right now, pretty hot here in the Med ;)
Nobody knows what happens to a submerged phone, but if you fish it out don't try to turn it on and don't put it into rice. Remove the logic board following the guide, put it into Isopropyl alcohol and let it soak there for an hour, then remove it and brush it with a soft toothbrush and let it dry for a day. Meantime buy a new battery and then try your luck, reassemble everything and hope for the best.
华为 P8 Lite 主板更换
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Thanasis Katsoydas 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 210
