跳转到主内容
加入维修社区 - 创建账户
-EF 卡口镜头 -光圈范围:f/3.5-36 -光学图像稳定系统 -超声波自动对焦马达 -内对焦系统 -支持手动对焦覆盖 -固定最小对焦距离:20 英寸 -72mm 滤镜接口直径
Zoom not working broken?
I'm not sure that this is the same lens as mine but this is my problem: I was trying to but my camera in the bag but the zoom was all out so it wouldn't fit. I tried to zoom out and I did but it was stuck and I had to force it a little and after forcing it it doesn't zoom in anymore. The ring turns perfectly but it does nothing. I also hear a little noise inside like a lose peace? Did I broke my lens?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
3个答案
sigma 50mm f/1.4 ex dg hsm
这个答案有帮助吗?
得分 0
添加一条评论
gopal jograna nagpur
123456789
这个答案有帮助吗?
得分 0
添加一条评论
For future reference, it's typically never a good idea to force the zoom ring to move if it's stuck like that. What could happen, which happened in your case, was that you were putting a lot of strain on some internal component and it eventually got to the point where it just snapped.
Whenever you do need to zoom a lens in or out to get it to fit into a camera bag, make sure to only do so using the zoom ring. Avoid pushing or pulling on the lens to zoom. It can put extra strain on components or put strain on them in a way that they weren't design to handle.
As to your question of whether or not it's broken, it definitely is. The mechanical connection between the zoom ring and the internal zoom lens elements have been severed in some way, which is how the zoom ring still turns fine while not actually effecting the zoom. The noise you here in the lens is most likely a screw or broken piece(s) of plastic. To know exactly what broke inside it, the lens would just have to be disassembled and examined.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Miriam Granadas 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 40
总计 1,209
