跳转到主内容
该机型使用非 Unibody 一体成型机身,使用 Core Duo 及 Core 2 Duo 处理器。
Display beginning to dim from the left towards center
The display on my brother's MacBook Pro 17" 2.5 GHZ (early 2008) has begun to dim, but just on the left side, as though one column of lights began to dim (it's not entirely out, just darker). Yesterday, the dimness extended to almost the center of the display, while the right side of the display is still normal.
It still functions fine when in closed-lid mode with an external monitor.
I found this thread about a stand-alone monitor starting to dim:
My mac display is dimming!
One person suggested that the inverter board is in need of replacement in that case, but it's a bit too much to generalize that case and apply it to a laptop.
Does this sound like a bad inverter board?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
This does not sound like an inverter problem. This is a failing CCFL backlight tube. Do a search on this site for "half screen problems", I've marked a lot of them. This is the most complete question I did on this issue: CCFL Backlight Repair and Information
Your best bet o0n this one will be to replace the LCD
This is the guide you may want to use: MacBook Pro 17" Models A1151 A1212 A1229 and A1261 LCD Replacement
Do a search for these part numbers: 661-4626, 661-4627
Here'a a pretty good price: http://www.lcds4less.com/Apple-laptop-lc...
这个答案有帮助吗?
得分 8
1条评论:
Apple MacBook Pro "Core 2 Duo" 2.5 17" (08) Specs
Identifiers: Early 2008 - MB166LL/A - MacBookPro4,1 - A1261 - 2199
完成的
添加一条评论
what is the parts number for the ccfl that fits the macbook pro a1212?
Update (05/22/2019)
what is the parts number for the ccfl backlight that fits the macbook pro a1212? Do you know if the MS140X450CWH370 CCFL for 17" WXGA LCD Screen listed in the link above is the correct one?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Garrett Gibbons 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 2,239
