跳转到主内容
加入维修社区 - 创建账户
一款 2001 年至 2004 年间生产的 17 英寸 Apple 电脑液晶显示器。
My mac display is dimming!
My mac display is at the highest brightness setting. It is about 5 years old, and I'm wondering if there is a bulb or something wearing out. If so, can it be replaced?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
3条评论
Can you comment on the model of the computer?
完成的
It is a desktop display. An Apple Studio 17 LCD that came with the original dual G5
完成的
if you need help taking it apart, i do have a teardown posted for this exact display.
完成的
添加一条评论
5个答案
已选择的解决方案
The inverter board is the part which needs to be replaced, a search finds them running about $130 dollars.
If you want an Apple ADC display, it may be less expensive and less work to find a replacement display on eBay or Craigslist. You might even find a larger Apple display for the cost of the repair parts.
You could also consider buying a new LCD - there are many good 3rd party options in the $130 range, and a new device, with newer technology, will probably outlast your G5...
I found an excellent take-apart at: http://mac-guild.org/display-repair.html
The class-action settlement probably no longer applies, as this model has long since been put on the obsolete list, BTW.
Good Luck!
这个答案有帮助吗?
得分 1
1条评论:
Thank you David, you are right that it is time to get a new monitor, and truth be told, a new hard drive.
完成的
添加一条评论
最有帮助的答案
It's very difficult to replace just the CFL bulb without damaging the rest of the display as you have to strip it completely down to pieces.
BTW you don't have to buy the complete cover, and or frame assembled once you get the old display apart on the back there's size and type information that will let you order a brand new replacement LCD online depending upon the size a new LCD should cost less than $100 for a 12 or 13" CFL probably what's in a machine that old.
N.
这个答案有帮助吗?
得分 1
添加一条评论
What type of mac display is it? most likely the display itself is going bad and the lcd needs to be replaced. it happens to the best of em. :(
这个答案有帮助吗?
得分 0
1条评论:
It's a 17" apple studio display (ADC)
完成的
添加一条评论
most LCD's will last about 60,000 hours beecase of there backlights, and if your an avid computer user it's about time for a new moniter anyways
checkout either this site or bestbuy to see if you can recycle it, I know that bestbuy will pay you to recycle your used electronics
这个答案有帮助吗?
得分 0
添加一条评论
Open System Preferences
  • Click on Energy Saver
  • Click on Display
IN energy saver option un-check Slightly dim the display
Automatically reduce brightness
In display section
Automatically adjust brightness
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
clinegunk 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 33
总计 4,390
