跳转到主内容
The Huawei P8 Lite is an Android phone, released in January of 2017. Model numbers: PRA-TL10, PRA-TL20, PRA-LA1, PRA-LX1, PRA-LX2, TAG-L21, PRA-AL00X, TAG-L32, PRA-LX3, PRA-AL00.
24 个问题 查看全部
My phone fell in a swimming pool, what should I do?
It went off and now the flash light is always on, but the screen doesn't work. I can't see any water on the screen but I see a little bit on the camera. It's impossible to turn it on, but the flash is always on!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Sofia Borges  you will need to treat it like any other water immersed device. The very first thing you want to do is to not try to restart/sync the phone. This may further damage your phone. The next thing to do is to clean it. Disassemble your phone using the help of videos like this as well as https://www.youtube.com/watch?v=CLVjt9t7...|this one]. You must remove all the EMI shields of the logic board. If you do not remove those you are not cleaning 3/4 of the board. Clean everything with +90% (no less than 90%) isopropyl alcohol. Follow this guide, and even so it was written for an Apple iPhone 3G all the points are still pertinent to your phone. Pay particular attention to the SMD components, check for charred missing or broken missing. You can then dry the board in an oven or equivalent at 220deg F (not higher;-) for a few hours. Best way to clean it would of course be through an ultrasonic cleaner. Consider professional help with that When it is properly cleaned, replace the battery. All these steps are to avoid delayed failure caused by corrosion. Once all this is done, reassemble your phone and reevaluate. Until you have done the cleaning you really can’t properly determine what is going on with your phone. You can always consider professional help with that and contact microsolder experts that specialize in this kind of work.
这个答案有帮助吗?
得分 4
添加一条评论
添加你的答案
Sofia Borges 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 8
总计 719
