跳转到主内容
External makes clicking sound but is fine on other mac
My friend has a MacBook Pro 13" which is basically unusable because it is so slow. I wanted to reinstall the OS to try and fix the issue.
So, I attached my external to back up all data before wiping the mac, but it wouldn't show up. I tried both ports, nothing.
I attached another of my external hard drives and the external was only clicking, I got a little worried and plugged the hard drive into my mac and it works like a charm.
None of my hard drives have shown up. What can I do? I need to do the back up in order to reinstall everything.
Thank you!
the external (in case this is important) is a 'WD My Passport Ultra'
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Try opening up disk utility to see if that detects the external drives at least. Have Usb ports been tried out with other external devices such as Usb stick, mouse, do they work at all ? If you have another Mac you can also try a network backup with ethernet or wifi if these work. In the worst scenario, you'll have to remove the drive from the Mac and put it in a usb enclosure.
这个答案有帮助吗?
得分 2
1条评论:
The disks don't show up in disk utility, but I just tried a USB stick and that one showed up. I will look into the back up via wifi option, my mac doesn't have ethernet.
完成的
添加一条评论
It sounds like your friends MacBook has a power issue which is also effecting the USB ports which is why the hard drives are not working here. If you have a power brink for your external hard drive that may allow you to get the task done.
An alternative approach here is to take the drive out and connect it directly to your Mac using a SATA to USB adapter like this one: Startech 2.5" SATA to USB adapter
This power issue on the logic board could explain the systems slowness. You’ll need to make a good inspection of the logic board for corrosion or liquid damage.
这个答案有帮助吗?
得分 2
3条评论:
Target Mode?
完成的
@mayer - Target Disk Mode might work as well! I'm worried the power issues may strain the system which is why I was aiming using an external drive which has its own power source or just taking the drive out.
完成的
That's actually great advice! I will try an external with its own power source. I was hoping very much not to have to open up the MBP
完成的
添加一条评论
添加你的答案
petra 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 9
总计 524
