跳转到主内容
加入维修社区 - 创建账户
Repair guides and support for televisions manufactured by Sony.
Image Issues Blue Lines os screen
Hi Guys
I have a Sonvy Bravia model KDL-50W685A that i bought at 2013 . Suddenly the screen initially start to have pixels randmly like when loos the HD Signal . but after that shows horizontal blue lines . The sound working ok and the channels change also .
I try to recycle the power and i leave it all night closed but this is not solve my problem .
I attach the photo with the problem .
Any ideas would be appreciated .
Update (07/07/2018)
Hi to all
I reseat all the cables for the board to panel bust still the same issue .
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
@costasc
please attach some pictures of what your screen shows. Use this guide 在已经存在的问题里加入图片 for that.
Horizontal lines are almost exclusively a panle fault. Once we see what your panel shows we can hopefully get you a better answer.
完成的
添加一条评论
2个答案
最有帮助的答案
I would suspect poor connections to the panel. Open up the TV and re-seat all of the cables. Start there and update this with the results.
这个答案有帮助吗?
得分 1
2条评论:
Hi Dan
Just to clarify , you mean the connection inside the tv and not the aerial cable
完成的
That is correct. Since the signal level between the logic board and the panel is so small, it does not take much corrosion or dirt to cause a problem. Simply removing the cable and reinserting it often will "cure" the problem.
完成的
添加一条评论
@costasc
that could be a main board issue as well as a panel issue. I would start with the main board, checking the t-con board as well. disconnect all teh wiring form the T-con board to the panel. then just connect one side. Let us know what it shows.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Costas 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 207
