跳转到主内容
加入维修社区 - 创建账户
发售于2017年11月3日。型号为 A1865, A1901。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供银色和深空灰色。(读音与“iPhone 10”相同)
iPhone X - Temperature Questions
Hey guys, have a question, my iPhone X gets warm when using snapchat up to 92 degrees Fahrenheit, but it also gets up to 90 degrees Fahrenheit when using safari or facebook. Texting and phones calls can also increase the temp but not as much only upto 84 degrees.
It generally idles a degree or two more then room temp and charging it can warm up to even when not in use.
Already done all of the resetting and setup as new.
Also dont believe its a hardware issue as this my second X, and also happens on my spare iPhone 7....
If any of you have a thermometer to check the temp that would be awesome.
Thank you.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Sorry was just hoping to get more info my apologies.
完成的
添加一条评论
2个答案
最有帮助的答案
Hi Rock,
90 degrees Fahrenheit is a pretty normal temprature, but if you want to lower the temprature you can always close background apps.
这个答案有帮助吗?
得分 2
1条评论:
My wifes 8 plus always seems to be slightly cooler though doing the same things...
完成的
添加一条评论
Thats OK, I figured that was the case. I think you're worried needlessly here.
Think of it this way... Your car sitting in your driveway will be about the ambient temp of the time, When you drive it it does warm up and the design of the engine dissipates the heat through a cooling system. But lets say you've got a leak in a hose so the coolant leaks out doesn't your car tell you its time to pull over? The temp gage and warning light should tell you.
Well, your iPhone is doing the same thing it will dissipate the heat as needed and if the phone is overheating it will tell you with a warning and then go into safe mode shutting its self off if you don't quit the app/process thats the cause or place the phone in a cooler location in case you've got it cooking in your cars window.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
xRock94 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 8
总计 464
