跳转到主内容
加入维修社区 - 创建账户
Repair guides and support for LED, LCD, HD and other Vizio TVs.
Can it be repaired?
Looks like the TV got hit in lower right hand corner. It has a spitter web looking spot and the colored lines running vertically and horizontally all the way across the screen from there.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@robertskelton21
going by your description alone, it sounds like a broken LCD panel. To verify this post some picutres of what the screen looks like with your question. Use this guide 在已经存在的问题里加入图片 for that.
If it indeed is a broken panel, then it becomes a difficult repair. Vizio use all kinds of different panel manufacturers for their TV’s even within the same model. So, you will have to remove the back of your TV and find the label on the LCD panel. On that you should find the manufacturer and the model number. Use those numbers and do an online search to see if you can find a panel for a prize less than a new TV.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Robert Skelton 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 48
