跳转到主内容
加入维修社区 - 创建账户
The Nikon D80 is a digital, 10.2 megapixel, single-lens camera that was released to the public in 2005. It is meant for digital photo-taking and filming.
Err Message/ Flash won't work
I have a Nikon D80. It won't take a picture on any setting and keeps showing an ERR message. THe flash will not pop up. Does anyone know what could be wrong with it? Or how to repair it?
Thank you!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Does it only give you an error after you press the flash popup button?
If I remember correctly the mechanism is fully mechanical (the popup function that is). It may be because the flash is not poping up.
Did you drop it or anything?
完成的
I will try that right now!..Thank you SO much for you advice!
完成的
添加一条评论
1个答案
已选择的解决方案
Gently push down on the top of the flash head and push the manual release button for the flash.The little hook that is holding the flash and is supposed to retract when you push the bottom to pop up the flash is probably stuck. Just a little explosion drawing, may help you out to see what is going on (hope I copied the right page:-) Good Luck
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Dawn 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 9,458
