跳转到主内容
加入维修社区 - 创建账户
惠普的一款一体式喷墨打印机、扫描仪和复印机系列。型号为 CX042A。
WHP or RSN #
Where do I find this number on my printer in order to set up wire less printing??
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
To set the printer up for wireless printing, turn the printer on, and make sure that the control panel shows "Wireless on". Press the Wireless button to change this setting if necessary. It will likely ask you for your wifi password. Input the password.
Now go to your computer and install the printer software. When it asks you for the type of connection, choose network rather than USB cable. Follow the instructions shown on the screen. At some point you will be prompted to select your printer. If it isn't shown in the list of printers, click the button to scan again. If it still doesn't show up, tell it you want to install a network printer via the USB cable. It will instruct you to plug in the cable. It will then do all of the necessary network setup for you, and it will then tell you to remove the USB cable.
这个答案有帮助吗?
得分 0
2条评论:
not really because my chrome books shows the printer but then asks for a password PSK or WAP or RSN where would I find that numbers??
完成的
I didn't know you had a Chromebook. I have no experience with Chromebook. Also, I have no idea what the WHP or RSN # are.
完成的
添加一条评论
添加你的答案
Eva Wegmuller 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 11
总计 378
