跳转到主内容
加入维修社区 - 创建账户
tahoe bogs down when accelerating
why does my 1999 tahoe bog down and sputter when i try to accelerate?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
What engine does it have? Standard or Automatic?
完成的
添加一条评论
3个答案
已选择的解决方案
No knowing what engine size or what transmission you got, I would think that it starts with checking your airfilter and air intake. Make sure it is clean. After that change your fuel filter and check your fuel pump, and fuel pressure regulator. The service manual calls for a pressure of 58-62 psi anything below that would indicate that a new pump is needed. The other option is the vehicle speed sensor on your transmission could be faulty. Have your vehicle checked for any error codes at a place like Autozone (it's free) and see what they come up with. Right now it does sound like a fuel problem . Good Luck and let us know how it is going.
这个答案有帮助吗?
得分 2
1条评论:
My tahoe was doing the same thing and Igor a new gas pump and fuel filter and problem solved.
完成的
添加一条评论
Check for vacuum leak ,pcv valve clogged, or clogged catalytic converter.
这个答案有帮助吗?
得分 0
添加一条评论
So..Check it...
5.7s Bucking or Bogging when under load.
Oddly, My 99 5.7(v8) was cured when I installed
new Manifold Intake Gaskets and Cleaned the
FI Spider & Injectors.
Make sure you/your mechanic uses the FELPRO 98000T kit.
^IT MATTERS.^
Use this gasket kit.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
internal46 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 34
总计 10,095
