跳转到主内容
加入维修社区 - 创建账户
由 Google 设计、华为制造的第 6 代 Android 智能手机。发布于 2015 年 10 月。
Phone not turning on?
I did a battery replacement, and the phone powered up, but the display wouldn’t come on at all, and I saw the “leaked ink” behind the glass, so I got the digitizer/display assembly, replaced it, put everything back, and now there’s no power at all. Any suggestions on what I might have messed up?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Did you disconnect the battery during the screen replacement process? Need to be careful of Static Discharge, which is something people forget. A small amount of discharge can easily damage the phone.
The other possibility is the LCD/Digitizer may be defective, unless you have another unit to test it on.
Last option is the board, whether there was a shortage or not, if the phone was dropped there is a chance that the boards power system may be at fault. So if you turn on your device and you can hear it, you know the screen works, 100% tested, then power may not be properly distributed.
Good luck, wish the best
这个答案有帮助吗?
得分 2
4条评论:
I get a flashing red light when I hook it up to the charger. I don’t think any static discharge occurred, and I did remove the battery. The phone will not turn on at all.
完成的
I'm going to try and replace the Daughterboard, maybe that's why it hasn't charged.
完成的
This is little late, but it was indeed the daughterboard! I took a better look at it, and there was obvious signs of water damage and corrosion.
完成的
Good Job finding the solution
完成的
添加一条评论
添加你的答案
Caleab Brown 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 27
总计 963
