跳转到主内容
加入维修社区 - 创建账户
第四代 iPhone CDMA 版的维修指南。型号 A1349,有8,16,以及32 GB 存储空间的选项。
Why did I lose the ringer mute and volume + and - button functionality
I just bought a new battery and the tools to replace it from ifixit and that went ok but I lost the function of the ringer mute and volume buttons on the side of the phone. Is there something in the battery replacement process (everything seemed to go without a problem) that could cause this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi Joseph, I would verify that all connections are being made correctly. Try disconnecting the battery, power draining the device by holding the Sleep/Wake button down for 5 seconds, check LCD, and Audio cable connections, and then reconnect the battery. Check to make sure that the flex was not damaged during the process by either heat or knicked by a pry tool. I hope this helps you out.
Best of luck, Alec
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Joseph Wolf 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 11
总计 106
