跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
Is there anyway to get data back from the phone before it’s set up ane
I know I’ve asked this question already and it’s been answered many times however I haven’t set up my iPhone 5 as a new phone just yet and I’m wondering is there anyway of getting my data back before I lost it I had 3 apps and 21k photos on the device I’d really appreciate it if there was a way to get the data back
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Stinger Solar  just like any other time (this is #5) you’ve asked the same question. If you do not have a manual or icloud backup, your images are gone. There are no magic tricks or magic software that can help you with this. There is nothing else you can do about it.
这个答案有帮助吗?
得分 1
添加一条评论
It really depends on how you had iCloud set up on your previous iPhone(s) or other iThingies. If you have your iPhone set up to back up your photos as well as system critical data to the cloud, it should be simple to get your original stuff working on the new iDevice. At some point in the initial setup on the new device, you are given the option of authenticating to your Apple ID (you need to be on either a wireless (preferred) or cellular data connection ). If your Apple ID is accepted, you are given the option to restore your previous iCloud data to your new device. If you select yes, it will likely take quite a while - depending on how much stuff is being restored - but things should work quite well once the process completes. This is actually one of the best things about hanging out in the Apple "walled garden". As long as you stick with Apple devices, migration is simple.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Stinger Solar 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 52
