跳转到主内容
加入维修社区 - 创建账户
Pontiac Grand Am 是 Pontiac 生产的一款中型(后来演变为紧凑型)轿车。1999-2005 年款是 Pontiac Grand Am 的最后一代。
Why dose my car keep overheating?
I have a 1999-2005 Pontiac Grand Am gt 3.4
let me tell u what i have done so far.
replaced:
water pump twice
thermostat twice
temp censer twice
intake gaskets / manifold gaskets
vale cover gasket
system been flushed countless times
resevoir and cap replaced
and still over heating radiator being replaced now! i know on these cars there was a problem with the dex coolant system and was a class action suit that ended in 08 and dose not help my only had it for 6months. but cant find what t do fix the problem. please help
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 14
14条评论
It's most likely the catalytic converter clogging 60 bucks cheap fix. I diagnosed my car at AutoZone for the check engine and that's what it was and it has fixed my overheating issue, also it you have a bad engine leak diagnose it before paying for an intake manifold gasket, right above and to the right of the oil filter on a 3.4 v6 grand am there's a oil pressure sensor and you have to buy a certain socket for it as well but if it is bad it will be pouring oil out like a small fountain so change it, ten dollar fix over a thirty dollar fix.
由完成的
Email me plz to fix my car problem .i hsve the same problrm after she cools off she ststts up again i changed two sensors landrade6635.la@gmail.com
由完成的
I have the same issue but i change thermostat twice i change my temp sensor once and my engine
Light not on but it's making a loud knocking
Sounds sometimes. Please help
由完成的
Fans on my 1999 Grand Am four-cylinder car will not come on car is overheating help please
由完成的
Hi my name is Rodney i have 04 grand am 3.4 go to pfyc.com they have a capers hi speed fan switch its about $100 it's comes with built in relays u can turn ur fans on manually and it won't interfere with ur control module takes about 30ins to install
由完成的
显示更多的9条评论
添加一条评论
8个答案
已选择的解决方案
You have replaced a number of parts, most of the cooling system, some of them twice. The first thing that jumps out at me is the electric cooling fan(s). Either the fan(s) are bad or the sensor that controls them is. Usually those fans always have electric and the sensor acts as a ground when they engage. There should be a fuse to the fans. Have you checked it? Are you certain your fan(s) is working? The next thing is collapsed hoses if your hoses aren't firm, hard to compress they need replaced. More than likely it is the fan(s) or hoses. If those check out good the next thing to consider would be a clogged catalytic converter. Autozone should be able to test for this for free with their diagnostic scanner. After that is timing, again a diagnostic scan would confirm this _ free at autozone. I have given you some things to investigate but to really help you with an answer I must ask for a little more information with all the parts you say you have replaced in a 6 month period of time. Is it only the temperature gauge telling you it is over heating or are there other signs of it over heating, if so what are they? Does the car lack power? What kind of mileage is on the car? When you replaced the water pump did you replace the timing belt either time? Have you tried running it with out a thermostat? What is the temperature rating of thermostat? Was the thermostat professionally installed? There should be more than one temperature sensor on the car 1 for the gauge the other to control the electric radiator cooling fan, you mentioned only replacing 1, which one was it?
这个答案有帮助吗?
得分 7
15条评论:
I replaced all 3 fuses for the fan, as well as the water pump. All brand new parts and my 1999 pontiac grand am 6cyl still over heats bad. The overflow hose attached to my recovery tank spews out all the coolant or water I put in, in less than 10 minutes I'm stuck on the side of the road and the car is smoking. I've only had the car for maybe 6-8 months and it's getting to the point of having to fill it up any time I stop anywhere.
由完成的
Hi Clint,
With the engine hot but off (remove the ignition key) feel the radiator hoses. If the bottom hose feels 'cooler' than the top hose it may be that the coolant thermostat is not opening. A way to test this (without removing it) is when the engine is cold, remove the radiator cap, start the engine and let it warm up. After a while if the thermostat is working OK you will notice that the coolant is "flowing' in the neck of the radiator. Be careful the coolant expands as it gets hot and may overflow thru the open neck. If the coolant doesn't appear to flow the thermostat hasn't opened. If the flow appears sluggish it may be that the radiator core has blockages.
由完成的
after putting in the coolant i watch to see if it is leaking abd it overflows from the hose on top of the recovery tank, it rises and falls as it pumps into the radiator. After doing this my recovery tank is bone dry and I have to put more coolant in it.
由完成的
I got 1999 pontiac grand am se fuses were good for fans but they never kicked in so I had a friend of mine show me how I hook it up direct to battery it can be a pain in the ass unless u install a relay switch inside car. I should have installed the switch also at least I knew it was wrking. Later on u found out my thermostat went out an sensor changed sensor one fan kicked in the other just clicked an did not turn
由完成的
These cars just have terrible cooling systems and I've found that they don't make a thermostat that keeps them cool enough. I ended up taking my thermostat all the way off and it worked great. Never overheated again.
由完成的
显示更多的10条评论
添加一条评论
Have you had the head gasket checked out? I have seen numerous vehicles overheat because of a blown head gasket, or other gaskets in the engine for that matter.
Are you constantly having to fill the car with coolant? Is there any white residue in the oil or on the oil cap? Do you notice any leaking coolant?
这个答案有帮助吗?
得分 5
3条评论:
None of the above
由完成的
It has none of the above, i bled the system it then spit antifreeze out the reservoir hose, then the heat goes cold then warm
由完成的
Hi @talia ,
As per the answer above, loss of coolant, signs of coolant on the oil dipstick or on the oil filler cap. Also white smoke out of the exhaust is another sign.
由完成的
添加一条评论
This is not an awnser but i have had 7 chevys with the same problem. (that includes pontiac) the 3.4 and 3.1 have a disconnect from the temp switch to pcm or pcm to the relay. If you turn on the AC yhe fans will run and if you unplug the temp switch the fans will run but you will have hard shifting in the trans because it gets info from the temp switch. I belive the problem is in the pcm not the harness as so many cars have that same issue. PS never change anything with out diag your waisting time and money and why would you ever change it twice really think about that.
这个答案有帮助吗?
得分 4
1条评论:
Hi, I have a Pontiac Grand AM GT 2000, I have exactly the same over heating trouble, fans not running until I turn on AC, do you think if I change the relay or PCM the issue will fix?; thanks a lot.
由完成的
添加一条评论
Head gaskets do it. Just got done doing them on my 2005. Cylinders 1 and 2 were bad. Replaced a bunch of other parts as well. No more over heating. Head gaskets were what took care of the problem.
这个答案有帮助吗?
得分 1
1条评论:
I had a similar problem after changing a water pump, that I could not figure out. In the end I fixed it with a gallon of water. I refilled the radiator with straight antifreeze rather than a 50/50 mix, not knowing that glycol does not transfer heat as well as water. Using straight antifreeze caused the car to run hot and overheat at low speeds. Using the correct 50/50 mix solved the overheating issue. Unfortunately, I didn't figure it out until after going through the time and expense of changing head gaskets.
由完成的
添加一条评论
I gotta 1999 pontiac grand am se 3.4 it ran ok when I first got it then seripeteen belt broke overheated a lil had problems since.got belt fixed then had problems with the fans not wrking also so hooked them up direct an found out outta 2 fans one wrked. Then this is why u never ever ever let ur woman drive ur car cause she overheated it for God only knows how long an I found out a sensor went out an thermostat fixed that problem an everything seemed alright till i seen resivoir start filling up with oil it started using more an more oil then an now my reservoir is filling up with antifreeze an leaking slowly just started doing that today 12-27-2016 oh their's more top of spring broke on drivers side drives ok but leans a bit lol window broke on drivers door friend owns pontiac grand am also he said his broke an he fixed his but had to use glue so I decided not to fix.oh yeah power steering pump leaked then went out 60 sum miles away from home I pulled over an the plastic pulley was off but still moving lol it got caught between the motor mount an the middle bar the pulley ran on so I got lucky drove it bk home.pulley had no middle to it anymore an wasn't turning but belt kept on a moving thank God now I'm thinking should I keep the car an fix heads or actually put another motor in it someone said probably just drop another motor in it if I keep it with all the problems these grand ama have I'm not sure loved it when I first got it brought used with only 112000 now 131000 if I can find a cheap motor 3.4 I probably will fix it
这个答案有帮助吗?
得分 0
添加一条评论
I have a 2003 Pontiac Grandam, last week all of a sudden it started overheating. Temperature gauge maxed out within a 5 minute drive.
I let it cool down ran it a couple of miles at night with no problems. Tried it again the following morning still no problems. At noon it started overheating again. These time even when car is cold and I add coolant it disappears.
No apparent leaks
I fill it up to max capacity and within seconds it's gone.
这个答案有帮助吗?
得分 0
2条评论:
The problem is related to the computer sending a ground signal to the cooling fans. I just fixed my daughter's 2003 Grand Am GT. The problem is what looks like a relay mounted to the driver's side fender wall. It's located directly across from the air filter assembly. Pontiac has located this device there and all your major grounds join here. The mounting plate attached to it becomes corroded which interferes with the grounding signal from the computer to turn on the cooling fans. The bolt that held it in place was actually so rusty that the head of the bolt had broken off as I removed it. I used a circular wire brush attached to my drill to remove the corrosion from the back plate. Used the same brush to create a new bear metal spot on the fender and a self taping screw to reattach it. No more over heating from there on, Fans triggered and varied speed as they should.
由完成的
I am having the same overheating with my sons 2003 Grand Am V6 The right fan comes on, but the left one never does. both fans work. Replaced several sensors with no progress. Your daughters car sounds exactly like my sons. Will check the Relay box when I get home. I hope you fixed it!!
由完成的
添加一条评论
Hi @pontiacuser2000 ,
It may be that the radiator core is partially blocked and needs to be flushed
Have you scanned the OBDII port to see if there are any 'codes' giving an indication of a problem?
There is a coolant temp sensor that sends the temp reading (actually a resistance value that changes with temp) to the ECU and at a programmed 'temp' setting the ECU operates the fan relay(s) which turn on the fans The number of relays it operates depends on the fan speed required and whether or not the A/C is operating.
Suggest that you may wish to check if the sensor is OK. I think that the temp sensor is located where the upper hose goes into the engine but not entirely sure of this
There are 4 relays in the engine fuse block for the fans according to this link (Scroll down to engine block fuse panel. Relays 8, 12, 14, 15)
If the temp sensor is OK check if the relay is operating. If not try another relay or check the relay's operate path.
这个答案有帮助吗?
得分 0
添加一条评论
这个答案有帮助吗?
得分 0
5条评论:
I'm an electronics technician and like all of you, I replaced all the normal parts and the radiator before figuring out this very simple repair.
由完成的
I should also mention that the O Ring on the cap of the coolant reservoir was broken and laying inside the passenger fender. This needs to be replaced to keep unwanted air pockets from developing in the engine. Now I'm done posting :)
由完成的
Plus I have no heat it blows but cold
由完成的
Check the psi on radiator cap , the replacement the parts store will sell you is incorrect and they do not have one that is required i had to get a factory cap from junkyard..
由完成的
I have an 03 grand am gt 3400 V6 and oil keeps getting into the resevoir cap but hasn't vice-versa I'm constantly adding water to resevoir but it's gone in no time, it recently started to get little hot after letting it run while I ran in a store for few mins but I didn't chance it further, and parked it asap, I've never had any type of smoke what so ever, and I've had all lines flushed completely out and after being parked a while I checked and again oil is in resevoir cap, I really want to drive my car, but can't afford a blown engine, Can anyone shine a light on my situation maybe??
由完成的
添加一条评论
添加你的答案
elyssa 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 50
总计 96,274
