跳转到主内容
加入维修社区 - 创建账户
三星于 2011 年发布的蓝光播放器,支持 Smart Hub 网络内容功能及 Wi-Fi。
Is this Region Free compatibility?
Can this device play region 2 dvds/ is it region free?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
Hi @jackieguttie ,
It is not region free.
It will only play region 2 DVDs if the player is already set to region 2
To find this out check the rear of the player for its’ region code setting information.
Here’s an image that gives the relevant information.
(click on image to enlarge for better viewing)
There is information available online that shows how to hack the player to make it a region free player but I cannot confirm that they are safe to use or not.
这个答案有帮助吗?
得分 2
添加一条评论
i am not entirely sure about this model, if you are talking about NTSC region 2 then you may be able to play those on this model, as for PAL and SECAM, unless it is region-free (highly unlikely) those cannot be played, there is almost no way to modify it to play dvds from other regions without bricking it
这个答案有帮助吗?
得分 0
添加一条评论
To make your DVD player region free, you need to hack it. Videohelp forum offers ''hack methods for different models''.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jackie Gutierrez 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 28
总计 2,544
