跳转到主内容
加入维修社区 - 创建账户
Freezer doesn't work properly. Not cold enough
My samsung upright refrigerator has the freezer in the bottom. It stopped working but the fridge part is working well. Actually the freezer becomes a fridge. Don't know why. We unplugged and kept it off for 24 hours, but problem still there. However, if we "power freeze", the freezer will work until we turn off "power freeze" button.
Not sure what to do by myself. Do I need to buy a new one?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
4条评论
Please give us a model number. Usually the freezer is used to cool the fridge.
完成的
It’s Samsung RB196ACBP. And 7 years old.
完成的
I have the same probleme inmy freezer
Beko RDNE500K21W
完成的
freezer not cool not snow freez only working
完成的
添加一条评论
3个答案
最有帮助的答案
The most common cause for this condition is a problem with the defrost system.
I would replace the defrost thermostat: 5303918214 - Refrigerator Defrost Thermostat Kit
Includes clip, leads, and heat shrink for replacing the defrost thermostat in your refrigerator.图片
产品
$33.99
这个答案有帮助吗?
得分 3
8条评论:
Thank you. I will try to replace it by myself. Don’t know how to start. First locate the thermostat, then buy the part and replace it.
完成的
is the right part in your link that I need to buy? Normally where is the thermostat? Thank you very much
完成的
yes. that the correct part for your model. As to where it is, I think my link has a 2 min video of how to install it.
Yep, here it is: https://www.repairclinic.com/Video/Video...
完成的
Thank yo mayer. I will give it a try
完成的
HI Mayer, Just want to know, is this part you mentioned for my Samsung fridge. Should it be defrost thermostat DA47-00243K? my fridge isSamsung RB196ACBP
完成的
显示更多的3条评论
添加一条评论
Take a look at this article:
https://www.networx.com/article/why-is-m...
这个答案有帮助吗?
得分 0
添加一条评论
This problem recurs in my fridge/freezer and I resolve it by taking out the inner panel of the freezer compartment to expose the freezer unit at the back of the freezer. This unit ices up occasionally and becomes a solid block of ice, the result of which is to severely impair the function of the freezer. Defrost until there is no sign of ice between the freezer pipes and fins etc, replace the cover and switch on. In my case with a Beko freezer, this does the trick and it works like new after defrosting.
这个答案有帮助吗?
得分 0
1条评论:
Thank you. i will try to melt the ice and replace the cover.
完成的
添加一条评论
添加你的答案
Min 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 18
总计 1,540
