跳转到主内容
The Acer Aspire One D150 is an affordable 10.5" laptop with an Intel Atom CPU. The Acer Aspire line is aimed at casual household users and covers both desktop and laptop PCs.
My Acer is NOT working
My ACER will not even open to the windows desktop it's stuck on PC Performance & Stability analysis report on WINDOWS TOOL and in each corner it says Safe Mode. Its getting frustrating because I cant do anything with it. HELP!!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
4条评论
I dont think my ACER is a D150 1920. Its just a KAV10 Part Num: MU.55700.020
完成的
Which version of Windows do you have on your computer?
完成的
I'm not sure which version of Windows came with this. The sticker is faded.
完成的
Tony Rush do you have a problem that we can help with ?
完成的
添加一条评论
1个答案
已选择的解决方案
Andrea you are in windows save mode. When you restart your computer do you get the option to start windows normally? When it first starts up in safe mode, can you got to the device manager and check on the systems icon you should see all your installed hardware. If any of them have an exclamation mark or a yellow sign check on those and best bet would be to uninstall those. I suspect you are having an issue with some hardware that windows can either not find or does not have the right driver for. Sometimes it is necessary to either reinstall Windows or repair Windows.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Andrea 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,560
