跳转到主内容
加入维修社区 - 创建账户
XV20 系列 Toyota Camry 是 Toyota 第 6 代 Camry 轿车。
1999 toyota camry speedometer and mileage not working
my 1999 toyota camry speedometer and mileage not working, and my car movement is bad .
Mise à jour (12/07/24)
Please help. I have 1997 Gx100 Toyota mark 2. Whenever the weather is hot, the speedometer goes off and the pedal areas gets too warm or hot for both the driver and passenger areas. The over drive sign appears on the dash board, gears starts to misbehave taking too long to change with a loud sound of the engine. Also the changing of gears is accompanied by a sharp rise of the rave count which quickly falls down once the gear has changed.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 7
3条评论
I noticed my speedometer stops working when the weather is hot. When it goes off, the gear change becomes difficult. This continued for some months, but it has completely stopped working now. Although, I observed that it came on last week when I used the air conditioner.
What is the likely fault and how do I fix it?
完成的
@suleimanshaibu check the answer and work through the description. This could be your instrument cluster or the speed sensor.
完成的
I’m having this problem with mine and the car won’t shift or go above 10 mph. Is it not the cluster causing the obo and the speedometer to not work? Also. It only does this on really hot days. Please help
完成的
添加一条评论
2个答案
已选择的解决方案
@uche4706 your car does not have a speedometer cable. Your Toyota's speedometer is controlled by a Speed Sensor (VSS)that is attached to the top of the bell housing. There is a spindle that matches up with the Flywheel, and there is an electronic pickup that detects how fast the Flywheel is spinning and Sends the signal to the Cluster. If the electronic pickup part of the Speed Sensor is not detecting how fast the Flywheel is spinning, your speedometer will not work. Now if your speedometer is not working, it could be the Vehicle Speed Sensor (VSS) but also the cluster itself (which would be my first choice since a failed VSS or ECM would most likely trigger a "Service engine Light" OBD code) as well as the ECM. You do want to check on this. The instrument cluster comes out with 5 screws. The speedometer assembly comes out with 5 screws. Look under the odometer display for the speedo chip, and right next to it, is the ceramic resonator. You can try to bend the resonator over about 45 degrees. If that doesn’t fix it then buy a new speedometer assembly. If unsure you can always post some good images with your question which will allow us to see what you see. Use this guide 在已经存在的问题里加入图片 for that. Not sure what you mean by the “car movement is bad”. So, we would need more information on that.
这个答案有帮助吗?
得分 4
添加一条评论
Check your speedometer cable -- make sure it is connected to the transmission. Perhaps it has become disconnected.
If that is not the problem, see if there is a speedometer repair shop in your area. Getting your speedometer repaired is a lot cheaper than buying a new one.
What do you mean by "the car movement is bad"? Can you be more specific?
这个答案有帮助吗?
得分 0
2条评论:
Greetings, I have a 1998 Camry 3.0L NAP to which I had already changed the VSS connector and cables. These replacement cables are white, without colors. Unfortunately these days I was working on one of the sensors and I accidentally broke those white wires and now I do not know what the order of them is. I have tried several combinations but I can not find the solution. The original harnes has three cables: one blue cable, one pink and one red.
If you have a photo of the VSS connector that shows what is the correct order and you would be so kind to publish it, I will thank you very much.
Sincerely,
Mr. Ruben Mendez
完成的
hey dodo , 99 camry does not have a cable
完成的
添加一条评论
添加你的答案
okafor 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 67
总计 16,370
