跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2694 个问题 查看全部
Why doesn’t my Battery Health (Beta) ever load for me?
I have recently updated my iPhone to iOS 11.4, and was excited to see my battery life because I’ve been meaning to get it replaced. I wanted to see my percent out of 100, however I cannot. Every time I open that section, it never loads for me. When I asked my mother once to check hers, hers loaded right away. To see if it needed more time, just last night I left it on overnight, and nothing ever loaded. How do I fix this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
3个答案
已选择的解决方案
First, for the sake of it, go to this page on the Apple website and input your serial number. You may be eligible for a free battery replacement.
As for your battery health, try to put the iPhone in restore mode. Leave for 5-10 minutes, then force restart it and see if it identifies the battery.
- To put it in restore mode: turn it off, press and hold the home button (for the 6S or older models; newer models require a different approach); while holding the home button, plug the iPhone in your computer. The iPhone will restart and show a cable on the screen.
- To exit restore mode / force restart your iPhone (6S and older): press and hold power button + home button until the iPhone turns off then back on and the apple appears on the screen. Then release the buttons and wait for it to finish starting up.
A word of advice: pull a back up before doing this procedure in case something is messed up and you brick the software. You could always restore it, but your data will be lost if you don't have a recent back-up.
Let us know if this helps.
这个答案有帮助吗?
得分 2
添加一条评论
Also read these and see what Apple did things to slow you down.
https://www.macworld.com/article/3245168...
https://www.theverge.com/2018/6/19/17478...
这个答案有帮助吗?
得分 2
添加一条评论
@hayley777 please did the first answer work for you,
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Hayley Lunsford 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 40,657
