跳转到主内容
Repair guides and support for a wide range of small engines.
103 个问题 查看全部
How do I get power too the rear tires
I have a 49cc 4x4 it starts fine sounds good when u give it throttle . When I lift the rear wheels off the ground and put full throttle the tires spin as fast as it should and sound good. But when I put any kid of wait on the seat. It doesn't move but it sounds like it wants too.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
'''++cpleafs++'''  since we have no idea what you are looking at, pictures would help tremendously. Use this guide 在已经存在的问题里加入图片 for that. Focus on the 4X$ model and the engine/transmission in particular. If it moves without load(kid) but not with load (kid), it is possible that this is a bad clutch/transmission or a bad carb/ valve adjustment etc. We need more information on the engine as well. Since you said that “but it sounds like it wants too. “ I assume that it does not stall, sputter or bog out. That would lead me to a drivetrain issue.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
cpleafs 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 41
