跳转到主内容
沃克斯豪尔汽车的修理和支持指南。 成立于1903年的英国汽车品牌。
58 个问题 查看全部
no spark firing opel kaddet
Hi,
I ve got a 200is kaddet with an import engine code XEV. The car has no spark at all, the following has been changed so far: Crankshaft position sensor, fuel pum relay, ignition coil.
What can cause a no spark condition in these cars? car is doing 300 000km on the clock.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
6条评论
Phelele Mazibuko can you let us know again what year your Opel Kadett is and possibly what engine size? What have you checked so far?
完成的
Its a 1998 year model, 2litre engine. Distributor less engine.
Changed the following:
Crankshaft sensor, fuel pump relay, ignition coil + leads.
完成的
You changed those parts because it did not have spark? It still has no spark so none of that made a difference? Ty to scan the ECU and see if you get any codes?
完成的
Will have it scanned on this comming weekend and let you know the codes.
Can a bad/failed engine knock sensor cause a no spark condition?
完成的
any help cz i have the same prob with my 1996 opel astra 1.6ie ... no spark
完成的
显示更多的1条评论
添加一条评论
1个答案
最有帮助的答案
'''Phelele Mazibuko'''  until we know exactly the year and model of your vehicle as well as the specific engine (X20XEV?) I’d go ahead and have the Kadett scanned. If you can’t for whatever reason, you can scan the ECU in a backyard mechanic way. It’s a bit lengthy to explain it on here so I attached the manual I have. Read through it and see if it makes sense. Once you know what the code is, let us know. file://C:\Documents%20and%20Settings\Alan\My%20Documents\workin
If your engine cranks normally but will not start because it has no spark it could be caused by:
  • On engines without distributor a bad crankshaft position (CKP) sensor, or broken, loose or corroded wires from the sensor to the PCM.
  • On engines with a distributor possibly a bad ignition module.
  • On engines with a distributor a bad pickup inside the distributor, a stripped distributor drive gear or broken, loose or corroded wires from the pickup to the ignition module.
  • Could be a bad coil on engines with a distributor and a single coil
As you can see without more details it will be difficult to find the right answer.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Phelele Mazibuko 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 36
总计 2,445
