跳转到主内容
GSM version of the fourth generation of iPad released November 2, 2012. Model Number A1459 / 16, 32, or 64 GB
43 个问题 查看全部
Can I order LCD ribbon cable ZIF con
I was trying to replace screen and did not do enough research before I started. Thought it to be no big deal because i replaced my iphone screen so easy. I was wrong. When removing the LCD ribbon cable I broke the socket it fits into, now I feel I'm screwed. What makes me even more stupid is I didn't backup first! Is there a way to replace this part? I have a picture if that helps you vision what i destroyed. Appreciate any help. Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
@missnotfix to post a picture with your question use this guide 在已经存在的问题里加入图片
完成的
添加一条评论
1个答案
已选择的解决方案
A picture would certainly help but if what I understood from your description is correct, a broken lcd connector on the logic board side, the iPad seems to be in trouble indeed. Replacement requires micro soldering skills and it's not very easy since a lot of pins hide behind delicate plastic. But please post a pic so that we'll be able to share what you see.
这个答案有帮助吗?
得分 1
1条评论:
will do, first thing in the morning. Thx
完成的
添加一条评论
添加你的答案
Traci 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 64
