跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Can I fix my water damaged motherboard?
My phone got wet while i was riding my back in the rain, to be honest i never thought anything would happen to it since very little water got to it. My friend called me several times and the phone was off so i know its not the lcd, while the battery was still connected the two black chips between the SIM got very hot, any ideas if it's fixable? i've already disassembled the logic board and i can see some white residue and water stains on some chips.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
'''++@enriquegaray98++'''
Good thing that you already removed the board. The next thing to do is to clean it. You must remove all the EMI shields of the logic board. If you do not remove those you are not cleaning 3/4 of the board. Clean everything with +90% (no less than 90%) isopropyl alcohol. Follow this guide, and even so it was written for an iPhone 3G all the points are still pertinent to your phone. Pay particular attention to the SMD components, check for charred missing or broken components etc.. You can then dry the board in an oven or equivalent at 220deg F (not higher;-) for a few hours. Best way to clean it would of course be through an ultrasonic cleaner. Consider professional help with that When it is properly cleaned, replace the battery. All these steps are to avoid delayed failure caused by corrosion. Once all this is done, reassemble your phone and reevaluate. Only after cleaning your board can you really evaluate what is going on with it. If it has shortened out etc. you will need the schematic for it, posses some testing and repair equipment and need to know how to use all that stuff. Sometimes it’s best to get some extra help from people like @refectio etc. for repairs like this.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Kike Garay 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 18
总计 6,436
