跳转到主内容
Can I upgrade my macobook a1181
I have a macbook a1181 with 2.13 ghz intel core 2 duo. Memory 2gb 800 mhz. With software mac os lion 10.7.5. Can I upgrade this thing. Thank you
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
最有帮助的答案
This is your machine:
I have changed the repair icon to help you get there.
Apple MacBook "Core 2 Duo" 2.13 13" (White-09) Specs
Identifiers: Mid-2009 - MC240LL/A - ''++MacBook5,2++'' - ''++A1181++'' -  ''++2330++''
https://everymac.com/systems/apple/macbo...
Standard RAM:2 GB Maximum RAM:6 GB*
RAM Type:PC2-6400 DDR2Min. RAM Speed:800 MHz
Details:2 GB of RAM is installed as two 1 GB modules, no slots free. *Apple officially supports a maximum of 4 GB of RAM but third-parties have been able to upgrade the system to 6 GB of RAM using one 2 GB and one 4 GB memory module.
Storage Interface:Serial ATA (3 Gb/s)
Pre-Installed MacOS:X 10.5.7Maximum MacOS:X 10.11.x*
This is an SATA II, so your hard drive upgrade would need to be backward compatible. An SSHD would be fine. This link will show you what drives will work for you:
MacBook Pro 13“一体式2009硬盘更换
这个答案有帮助吗?
得分 1
2条评论:
What would the name be of the ssd and the ram that I can upgrade my macbook a1181 to. Thank you
完成的
See the link provided by the guide I posted.
完成的
添加一条评论
I have a macbook 1181 mid 2009 it had 2x2gb ram and it was slow, I went with a ssd and it loaded faster, then I tried 1x 2gb and 1x 4gb 6gb total still was not fast enough then I went to 2x4gb 8gb total big improvement. And I am run High Sierra and downloaded NVIDIA GPU Boost 2.0 which boosts graphics performance and Geforse now which uses NVIDIA cloud graphics.
这个答案有帮助吗?
得分 0
1条评论:
What RAM did you buy to get the 8GB capability, please?
完成的
添加一条评论
添加你的答案
craftstasha 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 3,789
