跳转到主内容
加入维修社区 - 创建账户
第二代车型的车身相比前代 MDX 轮距更宽、轴距更长。引擎升级为 3.7 升 V6 发动机,调校后可输出 300 马力。其 0-60 英里/小时的加速时间仅需 6.5 秒,是本田迄今为止生产的动力最强劲的发动机之一。
How to replace sunroof switch from overhead console
I need to replace the sunroof switch on my 2011 MDX from the above console but I’m not sure how to take it apart after removing the 2 main screws. I can’t seem to see what holds it back.
Any help would be appreciated.
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
I was able to successfully replace the switch. The is 2 Philip screws in the sunglasses holder and two clips towards the sunroof. You just need to pull downward slowly and the two red clips will give. It was a faulty switch
Problem is resolved.
Hope this helps someone else. Good luck with your project .
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
x1 LbL Onetime 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 52
总计 1,712
