跳转到主内容
The Toshiba 40PB200 is a 40-inch flatscreen television in the PB200 series. It was released in 2012.
36 个问题 查看全部
Was watching it then picture went out but have perfect sound. .Turned
I have a 47" Toshiba smart LED t.v. and was watching it then picture went out the sound is perfect. I turned it off and on and did not work so I unplugged everything for half hour plugged back in and still no picture?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
'''++Barbara Martin++'''  let us know the exact model number for your TV. Since you have sound but no pictures it is possible that your backlight has failed. In a darkened room turn you rTV on and to a channel that you know is on the air. Then shine a flashlight at an angle against the screen, see if you can make out silhouettes etc. Then you will have to remove the back off your TV and take a look at all the boards and wiring. check for obvious damage like blown leaky caps etc. Post some images of your boards with your question so that we can see what you see. Use this guide 在已经存在的问题里加入图片 for that.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Barbara Martin 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 4
总计 81
