跳转到主内容
加入维修社区 - 创建账户
LG 37LF65 LCD 电视于 2007 年发布,提供 32 英寸、37 英寸和 42 英寸三种尺寸。
Is There a Secret to Using a 2.1 System?
I have connected my computer to my TV using an HDMI cable, so I do get sound from the TV when I use an Youtube video. The problem is that I have the 2.1 system connected to the jack in the rear of the TV - and it is picking up no sound at all.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
I looked at the on line docs for your LG 37LF65 tv and the only audio out I see is an optical output. Does your 2.1 audio system have an optical input? If so then that is how it needs to be hooked up to the tv audio output channel.
这个答案有帮助吗?
得分 1
1条评论:
Hi,
To add to the answer, you also need to set the TV speaker setting to OFF when connecting an external audio system.
Go to Menu > Audio > TV Speaker > Off then EXIT to return to the normal viewing screen.
由完成的
添加一条评论
添加你的答案
Richard Messina 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 18
总计 290
