跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy 平板电脑系列的第三代产品,配有 7 英寸屏幕,于 2013 年 6 月 24 日发布。维修此设备需要用到螺丝刀和撬装工具。该设备有白色和金棕色可选,提供 8 GB、16 GB 或 32 GB 存储容量,并配有一个最高支持 64 GB 扩展的 microSD 插槽。
Battery indicator is incorrect
Battery indicator is incorrect, shows 1% for ages but will work for ages after this but screen is hard to see as automatically goes to dark. Probably at about 50 % but shows 1% . Don't want to do a factory reset any other suggestions
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
thanks i will try this
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
The battery probably needs to be replaced, if that doesn't help then it's a board level issue that I don't think is worth repairing.
Battery is fairly cheap to replace.
Samsung Galaxy Tab 3 7.0 电池更换
Galaxy Tab 3 7.0 Battery
The screen flickering occurs when there is a critically low amount of charge on the battery so the battery is actually close to flat.
Replace a dead or damaged battery for your Galaxy Tab 3 7.0 Wi-Fi tablet with this part and fix issues with battery life. This is a used, OEM battery.图片
产品
$17.99
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Michelle Green 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 16
总计 1,586
