跳转到主内容
加入维修社区 - 创建账户
Dell XPS 13 笔记本电脑 9343 和 9350 型号的设备及维修信息,这两款机型均于 2015 年发布。
screen blank unless at certain angles
this seems similar to the issue of most of the Mac notebooks where the screen is blank at certain angles except this is happening with a Dell XPS13 that's been faithful for the last 2-3 years. a few days ago the screen started to flicker before turning off and despite a reboot the screen didn't come back on. it wasn't until the screen was adjusted that it was determined it works at certain angles and immediately goes black at other angles. any suggestions on what to do for this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
In my experience it is usually the cable that either hast to be re seated or replaced. If not the cable it could possible be the lcd itself. I would start with the cable.
这个答案有帮助吗?
得分 0
2条评论:
I've opened up the machine to verify that the cable is intact and that there are no awkward bend points. That said, I noticed the display is somewhat loose with some give before opening it past the 90 degree mark. seems like the trigger to turn off the display is getting triggered prematurely due to this... any suggestions on this particular model?
由完成的 分享
I would tell the pc to do nothing when the lid closes and see if that has any effect. If it is still doing the same thing i guess you would have to replace the sensor. I have never has to replace one before.
由完成的 分享
添加一条评论
添加你的答案
dimm0k 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 49
总计 2,072
