跳转到主内容
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1204 个问题 查看全部
问题已关闭
I went to turn on my computer today and only got a gray screen.
I tried reseating the ram, resetting the pram, and everything else I could think of. I then decided to try and wipe the hdd and start over, so I put the install disc in and held down the alt + whatever key to show you the disc. I then tried install the os again, but it just kept freezing and not doing anything. Is this bad logic board?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
Try holding +S on startup, once the code stops scrolling type fsck -fy. This will run a hard drive check, if the check repairs the hard drive, happy days! Your macbook should boot up when you type logout.
If it fails replace the hard drive.
If it passes but you still can't boot up, replace the logic board.
这个答案有帮助吗?
得分 2
添加一条评论
最有帮助的答案
Could be a bad board, but one note on the memory -- try one module in a slot, with the other slot free, and then the reverse. It's fairly common for a slot to go bad, and this is the way to test for it. Many people never test for a bad slot and end up giving up on a machine. Generally when a slot is bad but it has memory in it, the computer malfunctions.
这个答案有帮助吗?
得分 2
添加一条评论
thanks it work cool, now thank you!!! happy now so happy!
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 2,000
