跳转到主内容
加入维修社区 - 创建账户
2015 年 3 月发布的 13 英寸 MacBook Air 更新版采用了第五代 Intel Core i5 和 i7 处理器,性能和电池续航时间均有小幅提升。
Sleep Sensor/ Lid Sensor Location
Currently working on a customer's MacBook which apparently had water damage. Anyway, it keeps going into sleep mode unless I connect it to power and external monitor. Sometimes it realizes the lid is still open then switches back to the MacBook screen. Was wondering if anyone knew where the close lid switches are? I ordered a new upper case thinking the sensors were in there some where but it doesnt appear that addressed the issue.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
1个答案
最有帮助的答案
The sensor is on the daughter board, next to the ports there is a thickened PCB with a magnetic sensor on it.
Although I can’t say for water damage, you have to trace the wiring all the way to the SMC to find potential damage that is latching the signal.
这个答案有帮助吗?
得分 5
3条评论:
When you say daughter board, you arent referring to the I/O board where the MagSafe connects too correct? But instead the area where the MacBook screen cable attaches?
完成的
Just the magsafe part.
完成的
Thank you! For some reason, I didn't check on the underside of that piece and sure enough when I flipped it over it was corroded out. I ordered another one so hopeful the replacement will fix the issue.
完成的
添加一条评论
添加你的答案
Devin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 4,054
