跳转到主内容
HP’s affordable notebook computer, released in 2014, and is fitted out with Windows 8.1, an AMD E1 2100 / 1 GHz processor, and 4GB DDR3L RAM. It goes by the model number: 15-f009wm.
4 个问题 查看全部
Why is my pc screen gray?
My pc is about 4 years old and I'm having trouble with it. When I turn it on, the welcome screen is gray, but if I press esc it will go straight to the accounts. When I insert the password, I see the background of my account before it immediately turns grey again. At this point I don't know what to do. If you have any solutions please let me know.
Thanks for your time and patience
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
4条评论
Restarting it doesnt help either
完成的
Does it look like your screen is broken or does it look like your screen is having a black and white filter?
完成的
Well the screen is just grey and emitting light. I dont have a black and white filter and the screen doesn't appear to be broken or cracked
完成的
I think its the gray screen of death.
完成的
添加一条评论
1个答案
已选择的解决方案
@xtali that "gray screen of death"is a new one for me. Anyhow, connect an external monitor and see if that displays properly. If so you know your GPU etc. is okay. You also want to re-install the proper drivers for your hardware. "background of my account before it immediately turns grey again" this could be a driver issues. To verify this, change your computer’s BIOS to load from either optical drive or USB. Download a copy of any version Linux Live. Copy it to a USB/ CD and try to reboot your computer with that. If your display stays on properly you will know it is software related. If it does not it is your LCD. The grey screen simply means that your backlight is on but your screen does not receive video signal.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Talli 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 8
过去 30 天: 37
总计 1,596
