No power fuse location
My RX100V will not turn on. A shop suggested it could be a fuse. Where is said fuse and where might I find a new one?
Thank you.
If I recall correctly, all of the "fuses" in this camera are surface mounted fuses. These are about the size of a letter on a quarter. This is not a home owner repair. Some specialized equipment and experience is required for this repair. It will not be popping out a glass fuse and inserting another.
Sorry to bring bad news. The good news though, is that if the fuse is the problem, it is a relatively simple fix once you get to the area. BTW: the fuse should cost no more than $1.00
Dan
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 24
总计 1,860
5条评论
Did you get this fixed? I believe I have the same problem. Please let me know what you found.
由 Richard 完成的
I have the same on my Mk V. I dropped it about 3 ft on the grass. Totally dead. Hard to find anyone that will work on it. Tried a couple shops here in Houston. One told me to send it to some place in Vermont. I called them, they want over $400.00 to fix it. Not sure if it is worth it. I went back to using my Panasonic /Lumix. I have dropped that one onto a drive way off the roof, it has a dent butworks like a charm. I put the battery back in it, taped the battery access door shut, no problem. Would love to get my Sony fixed. Let me know if you have your repaired. I appreciate it. Thank you kindly.
由 Gary Griffith 完成的
Gary Griffith
Send me a message directly. I may have an option for you.
Dan
由 Abrsvc 完成的
@abrsvc Thank you. Any help is greatly appreciated.
由 Gary Griffith 完成的
Gary, please post back here if you find a solution. My Mk. V is still here not working.
由 Richard 完成的
