跳转到主内容
second internal ssd drive
Hi everyone,
Although this question had been posed previously here, I'm still searching the reason why I simply cannot place my additional SSD drive inside my Macbook Pro early 2011 .
I'm presenlty using this drive as an external one, but USB connection everybody knows is hard to use. This way, anyone availble who might had same issue and found a solution in his case would be appreciated. I've used this drive inside my previous macbook late 2008 and worked perfectly. Any clues???
Thank you very much indeed.
Rgds
Marco
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
Make sure you have formatted the drive GUID and Mac OS X journaled. The drive will work externally on just about any type format but not internally.
UPDATE
This model and the 2012 model had a lot of problems with the hard drive IR cable especially when upgrading to faster drives. I would suggest replacing that cable with the one from the 2012
MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable
MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable图片
产品
$34.99
这个答案有帮助吗?
得分 2
3条评论:
Thanks Dear Meyer. Appreciated your time and attenction disposed at my issue. FYR the drive is formatted as it should be to work properly at Mac's OS, I mean Mac OS X journaled. The point is: I simply can't make the OS recognize this additional drive when inside and connected as replacment to DVD drive within a proper caddie. I do not believe that saothing like that could be feseable previously into a Mac 2008 and into a one 2011 no longer could be done. Thanks again for your attention and help. Rgds
Marco
完成的
Please give us the make and model number of the drive and what version of OS X you are using.
完成的
OSX latest available and other details as follows
Intel 6 Series Chipset:
Fornecedor: Intel
Produto: 6 Series Chipset
Velocidade do Link: 6 Gigabits
Velocidade do Link Negociada: 6 Gigabits
Interconexão Física: SATA
Descrição: AHCI Version 1.30 Supported
OCZ-VECTOR150:
Capacidade: 120,03 GB (120.034.123.776 bytes)
Modelo: OCZ-VECTOR150
Revisão: 1,200000
Número de Série: OCZ-22C6L6ZX513M9UKV
Native Command Queuing: Sim
Profundidade da Fila: 32
Mídia Removível: Não
Unidade Removível: Não
Nome BSD: disk0
Tipo de Mídia: Estado Sólido
Suporte do TRIM: Não
Tipo de Mapa de Partição: GPT (Tabela de Partição GUID)
Estado S.M.A.R.T.: Verificado
Volumes:
EFI:
Capacidade: 209,7 MB (209.715.200 bytes)
Sistema de Arquivos: MS-DOS FAT32
Nome BSD: disk0s1
Conteúdo: EFI
UUID do Volume: 0E239BC6-F960-3107-89CF-1C97F78BB46B
disk0s2:
Capacidade: 119,82 GB (119.824.367.616 bytes)
Nome BSD: disk0s2
Conteúdo: Apple_APFS
External
Disponível: 103,02 GB (103.016.894.464 bytes)
Capacidade: 239,71 GB (239.713.435.648 bytes)
Ponto de Montagem: /Volumes/Data Base 1
Sistema de Arquivos: HFS+ com Journaling
Gravável: Sim
Ignorar Propriedade: Sim
Nome BSD: disk2s2
UUID do Volume: 9FB65B28-31F5-3488-AF00-0C1729BBFC14
Unidade física:
Nome do Dispositivo: SDSSDA240G
Nome da Mídia: SanDisk SDSSDA240G Media
Protocolo: USB
Interno: Não
Rgds
Marco
完成的
添加一条评论
If you don't mind losing your DVD drive, or at least making that external:
mac sales has the part you need:
macsales
and a suitable SSD will do the trick - they have combos
If you go down this route, check first what speed the DVD is connected at (3 or 6G) as the 3G SSD's will be slightly cheaper. To do this:
* bring up System Information...
  • Opt-Click on Apple Menu
  • Go to SATA/SATA Express
  • Highlight the Intel Series Chipset entry above the Optical drive
  • Speed is displayed
Just remember that your battery life will decrease a bit, depending on usage
这个答案有帮助吗?
得分 0
1条评论:
Dear John, Thanks for your tips and directions, Sorry still haven't any return on your suggestions. I'm too busy in my job and no time available to check it out and revert. I'll do this today and will revert with further details.
Rgds
Marco
完成的
添加一条评论
@bellarosa Hold on here! Depending on the exact model of your system you can encounter an issue with the optical drives clocking. So a fixed speed SATA III (6.0 Gb/s) drive or even an auto sense drive {one that is able to run in either SATA II (3.0 Gb/s) or SATA III (6.0 Gb/s)} won’t work!
If its one of the red marked systems in the notes at the bottom of the OWC Data Doubler you’ll need get a fixed SATA II (3.0 Gb/s) SSD for it to work.
Forget about looking at the System Report info as it will tell you the port can support SATA III (6.0 Gb/s) but it really can’t. You see Apple messed up the clock timing of the CPU which then mis-times the PCH. As it turns out the added logic Apple put into place on the HD port for HD crash guard smoothed out the glitch so that port will work at SATA III (6.0 Gb/s) speed unlike the optical drives.
MacBook Pro Early/Late 2011 (MacBookPro8,1)
  • 2.3 GHz (Core i5) or 2.7 GHz (Core i7) Will Work!
  • 2.4GHz (Core i5) or 2.8GHz (Core i7) Won’t work!
Check your SSD spec sheet to see what it says.
这个答案有帮助吗?
得分 0
1条评论:
I will. Thanks so far for your attention. I'll be back with further details.
Rgds
Marco
完成的
添加一条评论
添加你的答案
Marco Bella Rosa 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 79
