跳转到主内容
Released in May 2015 with a model number of CMP773 and a 9 inch screen.
Why won't my tablet turn on after I replaced the screen it was working
My daughter cracked the screen. I replaced it. It was working I tried some apps it was charging then my daughter got on it and it was at 12% and still on charger it went off and won't come back on it does not even show a battery symbol when charging.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@kastall you’ll have to recheck your work and see if the ribbon cables are still connected etc. There is always the possibility that the replacement LCD has failed. Also, if you have a USB AMMETER see if the tablet actually charges by pulling some amps. That would give you a pretty good indication that it is just the display that is not working.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Karen Wolfe 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 193
