Toshiba 32" television gone with black screen everything works fine ex
Toshiba 32" television works all good except the screen went black Is it a fuse .
Thank you
'''++Patrick OBrien++''' possibly but you will actually have to open it up and take a look. Before you do that, turn the TV to a station where you know it would have a picture. the dim your room and shine a flashlight at an angle against the screen. See if you can make out shapes, silhouettes etc. If so, it is your backlight that has given out. The possibilities with your TV could be a failed power board, failed, t-con board, failed LED driver or a failed backlight array. So, we will need you to let us know the exact model of your TV and once you open the back post plenty of good images of the boards etc. with your question. that way we can see what you see. 在已经存在的问题里加入图片
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 16
总计 5,640
2条评论
Led screen letter on
由 Shiva Jaat 完成的
@Shiva Jaat if you need some help to get things fixed, try to give us more information. What does it mean when you say "Led screen letter on"? The more information you give us the great the chance to fix it.
由 oldturkey03 完成的
