跳转到主内容
加入维修社区 - 创建账户
Anker Soundcore Pro 是一款便携式蓝牙音箱,由 Anker 于 2018 年发布。型号:A3142, AK-A3142013。
Where/How do we start opening this speaker?
Having the device not turn on now (similar to this), and having the device refunded already, I can tinker with this speaker any way I want it. One goal: to possibly find out the problem, and fix it.
The thing is, there is no obvious hole or secret thing to be screwed out or peeled off to get it opened, unless it requires peeling off the whole rubber skin of its bottom/feet..
I found this site which looks at its disassembled parts, but it's just that: already disassembled parts. The holes there suggests maybe screws, but...this speaker seems closed shut.
I tried opening it with the iFixit Pro tools I have, but to no avail.
...Maybe I have to pry harder? I might be fighting my way through adhesives here.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
How do you take apart a song core Bluetooth speaker where do you start taking it apart
由完成的
添加一条评论
4个答案
The front speaker grille pries off with a metal spudger (am I spelling that right?). The Torx heads are where the six posts slide into the front plate / speaker mount. They are style only and don’t unscrew.
Remove the ten screws; six across the top, four across the bottom. Two arrows show where to insert your spudger to pry the speaker plate out. Boom! You’re in!
On mine, the back of the micro USB input had come out and the jack’s tab to hold it weakened. I unplugged and removed the speakers, battery pack, & back port assembly. The assembly has two screws and needed some force with the spudger to loosen the adhesive holding it in. But it came apart with no damage.
I put all back in place and applied a blob of hot glue to the back of the micro USB jack to hold it together.
It all went back together just as easy and works fine now.
Cheers
这个答案有帮助吗?
得分 0
2条评论:
Worth trying. Why do micro-usb plugs fail so easily?
由完成的
Hi motokam, I really like this illustration but it's quite difficult getting around the terms such as metal spudger, torx heads etc. If you please, I'd really appreciate a visual representation of the disassembling of the Anker soundcore pro speaker.
由完成的
添加一条评论
There are only eight screws inside mine. The back feels like it's still attached at the top. Any advice?
这个答案有帮助吗?
得分 0
2条评论:
The newer Soundcore Pro+ perhaps? But from the images around, Pro+ looks no different.
Your speaker, at least from this image, looks to be a different speaker than the Soundcore Pro in question.
由完成的
This speaker is different from soundcore pro speaker.
由完成的
添加一条评论
Hi Leydar, Take off speaker grill, remove 8 screws. Turn over to back, gently remove back cover( tab in middle top, I had to lossen entire back before tabs would let loose). You now have access to insides. Good luck…
这个答案有帮助吗?
得分 0
添加一条评论
the top comes off first with clips
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lloyd Dunamis 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 19
过去 30 天: 57
总计 12,271
