跳转到主内容
The Lenovo Ideapad 110S-11IBR was released in September 2016 by Lenovo.
Update the 32 gb SSD to a 64 gb SSD
Can the ssd of the lenovo idea pad 110 S be upgraded??
thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
saludos pero si soporta un ssd m.2 2280 de 256 gb saludos amigos
完成的
添加一条评论
4个答案
已选择的解决方案
The 32 GIG ssd is soldered in, and must stay! However, what I have discovered thru the web, is that Amazon, (and other sellers) sell an SSD that fits in the OPEN SLOT of the Lenovo 110S, and I have done that to my 110S and reloaded win 10 to the added “Silicon Power 120GB M55 M.2 2280 SSD With R/W Up To 550MB/s (SLC Cache for Speed Boost) SATA III Internal Solid State Drive for Ultrabooks and Tablets (SP120GBSS3M55M28)” by making it the C: drive and making the original 32GIG drive the D: drive. Others may be able to help you if you want to save what is on your 110S before you do this, I did not, hence Microsoft reloading win 10 cleaned both drives, formatted them and reloaded my activated win 10. Hope this helps And I am adding a WARNING ———Also, be aware, not all Lenovo 110's have the extra slot. Before buying anything based on my comments, remove the rear cover and validate there is a slot for the added SSD!!!!!
这个答案有帮助吗?
得分 6
7条评论:
That info was not available when I gave my answer. Thank you for finding this.
完成的
I looked into it and it's true. This isn't hopeless like so many of these.
完成的
完成的
As follow up on my original Hard drive fix, the item I recommended has now failed on my 110S. Hence, I still recommend this fix, but do not recommend the“Silicon Power 120GB M55 M.2 as it quality and reliability, now as listed on Amazon had dropped like a lead weight. There are other choices that can be found by googling.
完成的
With the original 120GB failure, I found on Amazon for about the same price a Kingston A400 240G Internal SSD M.2 2280 SA400M8/240G Solid State drive that costs about the same as the failed 120GB drive and has a 5 Star Rating as listed on Amazon. I will continue to report on value and longevity! Double the GB for the basic same price and has 5 stars!
完成的
显示更多的2条评论
添加一条评论
Sorry, NO. It's all integrated into the logic board:
https://gfr2reviews.com/2017/08/19/lenov...
这个答案有帮助吗?
得分 2
2条评论:
I searched online and I found there is a M.2 SSD SATA port to upgrade the storage. Can you confirm that?? Thanks.
完成的
Yes its a M.2 2280 Sata III SSD 80mm x 22mm x 2mm
完成的
添加一条评论
I just did the upgrade to a 110S that had the slot. I had a friend give me a 110S that she didn't use and it had a miniscule amount of free space so I added a 128GB SSD and installed the win 10 OS on it and DIDN'T specify save files and now the original drive doesn't even show up! I thought I might use the space. Any idea how to do that or why it doesn't show?
这个答案有帮助吗?
得分 0
添加一条评论
It appears some how part of the microsoft add of the new hard drive did not clearly provide the way I did it. I was instructed what to do with both drives at Win 10 new load. I was asked what to do with both drives. Considering you have Win 10 now installed, you can do it again or...... read the following to get the original soldered in SSD showing and working.
https://www.dummies.com/article/technolo...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Yunier Suarez 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 39
总计 2,818
