跳转到主内容
加入维修社区 - 创建账户
HP Officejet Pro 8600 Plus 可以通过其型号 N911g 进行识别。该打印机于 2011 年发布,其外观为棕色,并配有触摸屏控制面板。
HP printer not accepting ink
My printer says the black ink is bad, bought a new one and still not working says ink is not original which it is so I bought a new ink cartidge and the same stuff, ink is not good, did Drs scanner and no help, what can I do.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
7个答案
已选择的解决方案
Are you on instant ink programme.? If so phone UP and they will send you new cartridges. If not try connecting printer with USB cable, not Wi-Fi , switch off, remove both cartridges switch back on and reboot using initial start up procedure.
这个答案有帮助吗?
得分 1
添加一条评论
Why are the Ink Cartridges not detected?
1. Printer Internal Memory Needs Resetting
2. Metal Contacts require Cleaning
3. Protective Tape or strips aren't removed
4. Disable HP Cartridge protection
5. Wrong / malfunctioned ink cartridges
6. Improper Cartridge Installation
Guided Steps of 123 hp printer setup ******Support And Installation Of Your Hp Printer. Wireless Printer, Android Printer, IOS Printer, Drivers Setup US.  Get HP Printer Support.
这个答案有帮助吗?
得分 1
添加一条评论
Took my Printer to fix, thanks.
这个答案有帮助吗?
得分 0
添加一条评论
You said that you took it to be fixed, it would be helpful to those reading this later, if you could share what they found, what had to be fixed, etc.
这个答案有帮助吗?
得分 0
添加一条评论
Is your hp printer not accepting the ink due to which you are unable to print? Then you do not have to have to get puzzled as you have landed in the right place. This answer will fix your issue in simple steps without wasting any time.
Why Does This Happen?
There can be many reasons for your HP printers do not accept the Ink. some of the reasons are as follows:
  • Toner is not compatible.
  • The cartridge is locked automatically.
  • Some changes in the settings of the printer.
And there can be many other reasons that may lead to the printer not accepting the ink. Let us now tell you how to fix the issue.
Getting The Printer Glitches Fixed!
To fix this issue the user may follow the steps below:
  1. Check if toner is fixed properly.
  2. From the settings of the printer, unlock the cartridge in case it has been locked.
  3. In case the cartridge is not detected then you can take the cartridge out and try a new one. Make sure that you do not have the local cartridge.
这个答案有帮助吗?
得分 0
添加一条评论
HP printer help and support
Need help with your HP printer? Well, now you can get 24*7 support of HP printer technicians who are here to assist and troubleshoot any issue related to the HP printers. HP printer help you find a quick solution for all models of HP printer. Our experts use top-class diagnostic tools to get through the issue.
这个答案有帮助吗?
得分 0
4条评论:
Actually, what you have posted is a lie, something it seems to be contagious nowadays. My question is VERY SIMPLE, but NONE of your pages upon pages and clicks upon clicks seems to want to answer my question...MY QUESTION IIS "WHY ON THE PAGE "SEARCH HP HELP" NO LONGER SHOWS THE INK LEVEL. The ink level ICON is still there but it's grayed out. WHY?????
由完成的
It looks as if the only thing PH is geared to is selling merchandise. How sad is that?
由完成的
添加一条评论
Hi,
If you've already tried multiple genuine black cartridges and the printer still reports them as bad or non-original, the issue is likely with the printer's cartridge contacts or printhead rather than the ink itself. Try cleaning the contacts, reinstalling the cartridge, and performing a printer reset. If the error continues, the printhead may need cleaning or replacement.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
elgranpiro 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 42
总计 4,151
