跳转到主内容
加入维修社区 - 创建账户
Nikon Coolpix S3100 发布于 2011 年 2 月,配备 1400 万像素摄像头、5 倍变焦镜头以及 2.7 英寸 LCD 显示屏。
Lens error on display.
Right after I power the camera on the lens pops out for a second and then retracts back into the camera and the screen displays "Lens error !" Is there a fix for this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
最有帮助的答案
When the camera turns on it attempts a "reset" to make sure that it is in a known state. The lens error message indicates that the lens reset has failed. Usually this means that the lens has not completed the extension and retraction in the correct amount of time, or it couldn't extend to its final outbound position. The camera requires service to clear up the problem with the lens assembly. You can check for dirt or debris around the lens or anything bent or damaged. But, other than that the lens assembly is a fixed and sealed unit and typically can not be "repaired".
Dan
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Todd Parisian 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 20
总计 1,161
