跳转到主内容
加入维修社区 - 创建账户
2014 年 10 月发布;搭载 Android 操作系统 v4.4.4,可升级至 v5.1;提供 32/64GB 存储空间,由 Verizon Wireless 独家发售。
Data Retreaval after Water Damage?
Hey everyone,
I'm trying to help my sister out with her busted phone. She dropped it in ocean water and picked it up right away. It was left to dry in rice but it will not turn on or charge. The battery seems to be totally dead at this point, too. It also does not do anything when connecting it to a computer. I did some cleaning to the inside to get rid of residue and yet it has not improved any.
All my sister wants is to get the photos saved on the phone off and onto a computer. Is there any way that this can still be done?
Thanks for your time and effort!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
When it comes to water damaged devices. It gets tricky. Most of the time its a 50-50 chance to get the device to power on again. Most of the time you need to do some soldering touch ups under a high power microscope. Also, use 90%+ alcohol to clean up any corrosion. If you can, check the voltage on the battery with a DMM should be about 3.5-4 volts. Unfortunately, if you can't get the device to power on you can't get data off. :(
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Joshua Enstad 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 515
