battery polarity for 1998 ford focus
i need to know what the polarirty is for my ford focus
fiestaernest your Ford, like any other vehicle at this point in time, uses negative to ground. The positive wire will go to the starter and alternator etc.
这个答案有帮助吗?
Hi,
To add to this answer, if the battery cables are colour coded the RED cable will go to the +ve terminal of the battery (also marked on the battery case) and the BLACK cable will go to the -ve terminal of the battery
Usually the right lead is going to be + while the left is going to be -. If you can post a picture that would help a lot.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 155
