跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2690 个问题 查看全部
No nfc after housing change
I recently refurbished an iPhone 6s using an after market housing. The customer who purchased the phone reported nfc was not functioning. Nfc antennas were changed without success. As a final attempt to fix, the logic board was put into an original Apple housing and nfc was restored. Does anyone know if this is an issue with after market housings?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Housings vary in quality, you may very well have received one with an issue. See this answer by Tom Chai (Wi-Fi signal weak after replacing housing) to a similar question.
The NFC is also sensitive to how the NFC bracket is placed in relation to the camera. You don't give the impression of being a noob so I am assuming you've done a few of these before :>). That said, all of the antenna magic is based on the proper sequence of installation (Step 39) of all kinds of little conductive thingamabobs with the proper screws.
It's possible you made a misstep on the replacement housing.
这个答案有帮助吗?
得分 2
2条评论:
Thanks for the answer. I can only put it down to the quality of the housing. I am very particular in transferring every single component, even down to the stickers. I tried a different nfc bracket, which was unsuccessful, thus reverting to an original housing.
完成的
Hello, I got my iPhone 6S housing replaced. I've noticed that the NFC doesn't work, if I replace the rear case for an original one, would it work?
完成的
添加一条评论
添加你的答案
Steve 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 921
