跳转到主内容
加入维修社区 - 创建账户
A general-purpose audio device that transmits low audio frequencies to your ears.
How to wire subwoofers
New at the car audio I have 2 12 inch svc 4ohm subs and 2 dvc 6.5 4ohm subs what's the best way to hook them up and what kind of amp should I use
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Please have a look at this instructable https://www.instructables.com/id/Install...
这个答案有帮助吗?
得分 1
3条评论:
Know a little I never got into the channel amps and I'm sure I need more then one I'm thinking about another amp I have I mono amp now for the 12s
完成的
As long you amplifier can handle 8 ohms - you should be more than fine with both subwoofers on one amp. Using 2 different amps you could have muck ups with sinc witch could cause delays on other sub.
完成的
Well the I have now is a boss 1100 riot mono so I have to get a 2 channel amp ?
完成的
添加一条评论
添加你的答案
jeffbennett789 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 20
总计 334
