跳转到主内容
加入维修社区 - 创建账户
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
sim tray will not install
removed the tray and installed sim card. Whenattempting to return tray, it will not go all the way in. It will with the sim removed.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
it may be the flipper that ejects the sim tray is sticking. if you follow any of the repair guides for this phone (the link is the hammer at the top of screen-chose iphone / 3g) to take the front display off you will then be able to have a good look at your sim slot. You can try putting the tray in with sim in etc and see what it's catching on.
这个答案有帮助吗?
得分 3
3条评论:
Flipper, like a little dolphin? ;-)
完成的
a really little dolphin, bit bigger than some zooplankton...
完成的
the other reason for sim sticking is that the motherboard isn't installed properly..if you look in the sim slot you will see this. Remove the display and motherboard and reposition by placing sim end of motherboard in first under the little tabs of the metal rim.
完成的
添加一条评论
添加你的答案
keith 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 1,649
