跳转到主内容
加入维修社区 - 创建账户
非苹果电脑键盘维修指南。
capslock key is unresponsive
so i'm currently using a red dragon mechanical keyboard k552-r, and the issue i'm having is my capslock led toggles on and off as normal but the key itself is unresponsive. So, to sum it up: I can't capitalize anything less I press shift. I've tried multiple keyboards and i get the same problem so i'm sure it isn't the keyboard. Is there anything you guys can help me with? I apologize in advance if this question has been asked. P.S the caps key sometimes works, and i'm running windows 10.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
i downloaded, "Reimage Repair" and unfortunately, i had to pay, but nonetheless it fixed the problem as well as others i was meaning to fix. thank you guys.
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
Hi Dizzy,
Try enabling the on screen keyboard and toggling the caps lock there. Does that work?
Do you by chance have any third party software which may use the caps-lock key as the trigger?
You can also try resetting the caps lock by following these steps.
这个答案有帮助吗?
得分 1
添加一条评论
Hey bud, how long has it been playing up? Is it a new install of windows 10? Is it 32 or 64 bit? Has something changed recently? Like hardware/software? I would suggest uninstall and reinstall drivers from manufacturers website and try compatibility mode. Then post back with the results.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dizzy 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 31
总计 3,019
