跳转到主内容
加入维修社区 - 创建账户
首先 你得要准备一部iPad Air(1rd Gen)只支持Wi-Fi的机型 这里我们指的是A1474机型 它拥有64位的A7双核处理器并拥有16,32,64GB甚至是128GB的内存选择
iPad screen 'ghost touching' even worse after attempted repair
My iPad would sometimes sporadically ghost touch the screen during use. After searching I tried following the advice on Digitizer activating itself after digitiser replacement. Unfortunately it seemed to make things worse with the screen now very frequently ghost touching. I also must have not put the home button back on correctly as it won't click when pressed like normal. I put Kapton tape on the edges of the digitizer and then replaced the adhesive pads. I didn't remove the LCD panel so a small part of one of the adhesive pads had to go over the cable connecting the digitizer to the LCD but it didn't look like that would cause an issue. Did I put too much tape on? Is there something else I should have been watching for that could cause worse ghosting? Thanks for the help!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
I have bought several ipads that have had a new digitiser installed and each time it was the ribbon that had a break in it...the plastic is very brittle and is only safe to be bent once or twice....it must be under the LCD not on top where it will be pressed into a tight bend when the digitiser is laid on it....sometimes the break is hard to see but using another digitiser solved it every time..people are buying cheap digitisers and doing it themselves....cheap ones are cheap for a reason....bend only once or twice
完成的
添加一条评论
4个答案
已选择的解决方案
Was the ghost touch happening on an Apple original, non-repaired iPad digitizer or did it start occurring after a repair?
Low cost digitizers suffer from ghost touching, even with tape applied so this could explain your issue if the screen was ever replaced in the pats. If the digitizer is original, then tape shouldn't be necessary and it is possible that the panel is simply just defective.
Now if this device was ever repaired, dropped or came into contact with water, then there could be other issues but I'll wait for your feedback on that.
这个答案有帮助吗?
得分 2
7条评论:
I got it from a friend who did say he had repaired something on it but I'm not sure what. Very well could have been the digitizer, I'll have to check with him and see. If he had replaced the digitizer would a simply better quality one possibly be the fix? I don't believe it had any issues like water damage, he would have warned me about that when he sold it.
完成的
In that case, a better quality digitizer should do the trick.
完成的
Yep, confirmed that the digitizer was replaced. When I get a new one do I need to put the Kapton tape on it even if it's higher quality? And if so does it need to be on all four sides or just the bottom by the home button?
完成的
On the mini it was REQUIRED but I haven't seen the need to do so on the iPad Air. That said, I buy the highest quality digitizer I can find.
完成的
Other than the one sold by iFixIt is there a brand or site you recommend for quality ones? I've been burned too many times by crappy replacement parts from what appear to be reputable sellers on Amazon and eBay.
完成的
显示更多的2条评论
添加一条评论
Hi Lucas,
It sounds like your iPad display is having symptoms of false touch, and I'm happy to help. If you haven't already, please try restarting your iPad firstly.
I had encountered iPad ghost typing issue with my device before, but it randomly occurred, I had thoroughly solved the issue by following some of these tips provided by lifewire, I do not know how these tips will be applicable to your case, but I hope that this can help you some way.
https://www.lifewire.com/fix-ipad-ghost-...
You can just try out these methods straight away, back up your iPad before proceeding if there's anything important on your iPad.
这个答案有帮助吗?
得分 0
4条评论:
I've tried the restart but haven't reset to factory settings. I will attempt it and let you know if it works.
完成的
Yeah, factory reset didn't work. Guess I'll be getting a new digitizer! Thanks for your help tho!
完成的
So sorry that I didn't help you, hope that you'll figure out a way soon. Good Luck!
完成的
If I replace the screen ( mine is broken ) will that stop the ghosting
完成的
添加一条评论
My iPad Pro has been suffering from ghost clicks. No amount of resetting would fix it. It wasn’t random, but always on the left side, where the lightning port is.
Thrn I read a posting elsewhere that described how they had a similar problem that only happened when they used it while charging. So I gave it a go. Sure enough, no problems when not charging. So I tried swapping the (third party) charging cable.
The problem seems to be cured.
这个答案有帮助吗?
得分 0
添加一条评论
I just posted on an ipad4 topic what worked for me. Counter-intuitive solution! But there seems to be lots of causes for ghost touches on ipads.
"Ghost touching after digitizer replacement"
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lucas Hewitt 将永远感激不已
浏览统计数据:
过去 24 小时: 7
过去 7 天: 17
过去 30 天: 71
总计 18,544
