跳转到主内容
任天堂 Switch 是一款可以通过扩展坞在电视和路上玩的游戏掌机。发布于2017年3月3日。
20 个问题 查看全部
Strip screws? How to fix?
Hi i screwup my side console, by stripping one of the screws. ( i used a y00 instead of a y000). Rubber band and super glue didnt work. To remove glue i use a drill bit (1mm), now there is a counter sunk hole. Ideas?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 8
添加一条评论
5个答案
已选择的解决方案
Sounds like you already have drilled a hole there so I would just get the next biggest drill bit and drill it more. You might even need to use the next biggest bit after that. Once you drill the head off then you can usually take it apart more until you can get to the screw and use pliers to turn it out.
Hope this makes sense.
这个答案有帮助吗?
得分 7
添加一条评论
Try this
Precision Screw Extractor Set
Four different sized extractor tools to help remove fasteners or screws with stripped heads. Driver head is claw shaped for maximum grip. Sizes range from 1.1mm to 2.0mm.图片
产品
$24.99
这个答案有帮助吗?
得分 3
添加一条评论
Welp.. Y00 is correct you might have presed a lot. Y00 works for me
这个答案有帮助吗?
得分 1
添加一条评论
So how was this problem solved? I have the same situation. Please help.
这个答案有帮助吗?
得分 1
1条评论:
Have you tried 如何卸下滑丝的螺丝 already?
完成的
添加一条评论
Needle nose pliers is what worked for me
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jonathan ambrose 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 23
过去 30 天: 83
总计 33,262
